How can I combine 2 audio devices into one virtual audio device.
By
Ryzenuser19
in Audio
in Audio
Solved by CriminalAphid26,
VoiceMeeter - https://www.vb-audio.com/Voicemeeter/
This allows you to select multiple audio devices in your pc as inputs to then output to whatever speakers you want, which sounds like a similar program you found on github
x84 ·
Posted in Troubleshooting1 -
1
Void_dweller_ ·
Posted in New Builds and Planning2 -
1
Jafari ·
Posted in CPUs, Motherboards, and Memory2 -
S1mplic1ty ·
Posted in General Discussion8 -
uncanny_mac ·
Posted in New Builds and Planning6 -
1
QuantumSingularity ·
Posted in Troubleshooting2
