Rgb on Fans not turning on but fans are spinning
Solved by Agent Crimson,
If there isn't a rgb header return it. Because to control it there should be one. And even if it is like a self lit one like no user control etc then it should out right work if you connect it to molex. So your fan is busted
4
zamplex ·
Posted in Servers, NAS, and Home Lab12 -
Chaos Network ·
Posted in Graphics Cards3 -
2
Los_Jackal ·
Posted in Storage Devices6 -
TurboTrym ·
Posted in Programs, Apps and Websites1 -
Pepegovich ·
Posted in Troubleshooting0
