3 pin fan on a 4 pin mobo header
Solved by hadesjoy72,
Hello fellow computer enthusiasts. I have a problem i have a mobo (asus maximus hero) with only 4 pin fan headers. the one thing i wanted to have are led fans but these are 3 pin connectors. The AF120 led fans. My question is can i plug a 3 pin connector on to 4 pin header?
I hope to hear from you guys soon.
See yall
jurian
(please don't mind my English i am Dutch.)
Your ok to plug in the 3 pin to 4 pin fan header, the only thing is you will not have the PWM control, meaning that your fan will run at whatever its rated at constantly.
