Which monitor is best for me?
CharmingPanda
I Have a intel core i5 9600k
with a RTX 2080 Super, and gonna upgrade to a 2080 ti in a few weeks.
But i have a 144Hz screen right now that is 23.6 inches (Curve) one of Asus TUF models.
But i am not really satisfied with it tbh.. I Want something more, more juice. Like 240hz or even a 1440p.
Anyone have any recommendations. The price can go up to 400-500$ ❤️
Don't.. Don't do that. That makes no sense.
Anyways:
I'd go with this one:
https://pcpartpicker.com/product/8HF48d/acer-vg270u-pbmiipx-270-2560x1440-144-hz-monitor-vg270u-pbmiipx
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
if you want to upgrade from an excellent card to something *slightly* better, why not at least wait for ampere?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Anyways:
Though thats 6-bit+FRC and TUF Gaming VG27AQ for example is 8-bit native. But I don't know if that makes up 200€ price gap.
... response time is supposedly even better on Acer  - https://www.displayspecifications.com/en/comparison/576fcd906
I edit my posts more often than not
That's the thing though- most people won't even notice the difference, and especially at a higher price tag
Why did u get stuck on the part i did not ask for help? ?
i get them from my sponsor, so i dont pay anything for it. And i am giving back the 2080 super.
Just now, CharmingPanda said:
What makes no sense?
The 2080S to the 2080Ti, but I just read your other post.
sorry sorry, its just a lot of money for not much more presuming you were buying it. anywho, i'd have to check the exact model number but the monitor i have is quite nice, and fairly cheap for 1440p 144Hz
No worries buddy, i know its a strange upgrade. But since i am gonna have my computer running their art. They wanted me to run the latest graphics card, and ofc i am not dumb. I dont say no to a free 2080 ti ?
But thats the thing, idk which one i should get. I Would love to have a 1440p screen with atleast 144hz and if it is a 240hz. Thats a big plus also. Does not have to be 1440p ofc. I Rather take 240hz over 1440p
ah okay
I wouldn't...not worth the upgrade.
Whats not worth? Upgrading screen?
Sorry, I meant upgrading the 2080 super to the ti...is there a specific reason why you want the ti?
IPS:
ASUS TUF VG27AQ
BenQ EX2780Q
VA:
Dell S3220DGF
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
I Am recieving the TI version from my sponsor, and i am giving back the S version. So there is not a specific reason why.
