Bypassing charging port on old laptop?
Solved by kelvinhall05,
It's a little hard for my retarded self to understand what you're asking.
If you're asking if it's possible for you to chop off the dc plug and dc socket from the charger and laptop respectively and then solder the wires together, then yeah, that would work.
2
Vibes NoVibes ·
Posted in Troubleshooting1 -
5
kim921 ·
Posted in Build Logs4
play_circle_filled
Latest From Linus Tech Tips:
Why Do Youtubers Keep Destroying Companies - WAN Show April 19, 2024
