Connect 5.1 surround to a tv??
andybeech
Hi so my brother has got a 2nd hand 5.1 surround but it has rca connections on the back how do you connect it to a tv to get 5.1 surround.
Thanks
Gaming rig: Windows 10 Home 64bit Gigabyte z370 hd3p Intel I5 8600k 16Gb Corsair Vengeance DDR4 240gb SSD & 1tb HDD Sound Blaster z, 2070 RTX windforce, Cooler Master Cosmos Case
Stream rig: Windows 10 Home 64bit, Gigabyte GA-970A-DS3, Amd FX 6100, 12gb mix ddr3 ram, 1060 3gb gtx windforce oc, avermedia c985, 120gb ssd, 500gb HDD,
Thanks
This device doesn’t look like it does 5.1 splitting.  At least not with the connectors shown.  It wants pre-split 5.1 input.
As far as 5.1 input it looks Pretty straight forward.  RCA is either 2 pin or one pin.  In this case it looks like one pin.  5.1 is actually 6 channel, but one isn’t amplified so it’s 0.1 instead of 1. You’ve got the 6 channels sitting there labeled.
im assuming this is the back of the second hand 5.1 device.
The outputs on the TV are what matter.  If the TV does 5.1 splitting you’re golden.  If it DOESNT, and only has 2 channel out, more inputs will need to be found on this device, or a different device will need to be found.
What needs to be seen is what the outputs on the TV are. They can vary wildly.  Only half the required information is here.
I don't think such a device actually exists. At least I haven't found one. HDMI audio requires a video signal, and there's nothing that splits out the audio channels into 5.1 analog that I've seen. Haven't seen anything for optical that does more than stereo either.
This would probably be pretty good for a PC with 5.1 analog jacks though.
#Muricaparrotgang
Isn’t that called audio dembedding?
Thanks
optical from tv to THIS , then rcas to speakers
no optical then if having to pull from hdmi then THIS ...a little pricey
Hmm ok not an easy one then to do.
