So Linus made a mineral oil filled computer?
Solved by TempestCatto,
A question like this pops up every now and then here on the forums, use the search function and you'll find out why it's not a good idea. The TLDR is the isopropyl will literally dissolve PCB's and the like, thus exposing traces and everything goes to shit from there. Your parts will literally be eaten alive. So no, it will not work - period.
7
1
Bory Brason ·
Posted in Displays3 -
2
Da_maniaC ·
Posted in Peripherals5 -
Evan37 ·
Posted in New Builds and Planning2 -
1
HYSTOU ·
Posted in Laptops and Pre-Built Systems4 -
Sychicyuto ·
Posted in Troubleshooting12
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
