144hz monitor under 300$?
peopol
Hello. I'm currently looking for a display that has decent reaction time, eliminates most ghosting and is under 300$. I need it mostly for FPS games. Preferably flat, but i'm eager to cry curved.
I have a good one its aoc 144hz borderless i bought it where i live for about $200
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
forgot to say it maybe is only accesible to buy in europe
Reminder⚠️
If your looking for 1440p then this dell one is good
https://www.amazon.com/Dell-27-Inch-LED-Lit-Monitor-S2719DGF/dp/B00N2L5CXO/?tag=linus21-20
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
I can recommend the AOC 24G2U. Those are 1080p 144Hz IPS Panel and flat. I'm running 2 of those for a few weeks now and they are great so far
Gaming Rig: Ryzen 9 5950x | 2x16GB DDR4 3200MHz | XFX Reference 6800 XT | MSI Unify X570 | Corsair MP600 2TB, Samsung 850 Evo 500GB | bequiet 850W Straight Power 11
Server: Ryzen 5 3600 | 4x32GB DDR4 ECC 2400MHz | Asrock Rack X470D4U | Samsung EVO Plus 250GB, 6x Seagate Exos 8TB, Samsung 850 Pro 1TB | bequiet 550W Straight Power 11
Both is my sig were less than that. I’m sure sure more, newer models can be had.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
Try the AOC 27G1G4 it's a 27" 1080p 144hz curved monitor... It's not HDR but it's decent enough and well within your budget.
System 1: Gigabyte Aorus B450 Pro, Ryzen 5 2600X, 32GB Corsair Vengeance 3200mhz, Sapphire 5700XT, 250GB NVME WD Black, 2x Crucial MX5001TB, 2x Seagate 3TB, H115i AIO, Sharkoon BW9000 case with corsair ML fans, EVGA G2 Gold 650W Modular PSU, liteon bluray/dvd/rw.. NO RGB aside from MB and AIO pump. Triple 27" Monitor setup (1x 144hz, 2x 75hz, all freesync/freesync 2)
System 2: Asus M5 MB, AMD FX8350, 16GB DDR3, Sapphire RX580, 30TB of storage, 250GB SSD, Silverstone HTPC chassis, Corsair 550W Modular PSU, Noctua cooler, liteon bluray/dvd/rw, 4K HDR display (Samsung TV)
System 3 & 4: nVidia shield TV (2017 & 2019) Pro with extra 128GB samsung flash drives.
