-HELP- Asus Z10PE-D16 WS - Dual Xeon E5-2698 v4 ES
Hi all, I am hoping to get some help with my system, my system is completely unstable I fresh install windows 10 and sometimes my system would work fine for a couple of days or weeks and then I will have all sorts of Blue Screen non stop on a constant basis until I reinstall windows 10 of which I will keep having different Blue Screen errors until I finally get an installed working windows for another few days to weeks.
I have used multiple different Windows install including Official Microsoft Windows 10 Installers
My component
Asus Z10PE-D16-WS - BIOS 4101
Dual Intel Xeon E5-2698 v4 ES - Boot screen shows (Genuine Intel(R) CPU 0000 @ 2.00GHZ
2x Crucial CT32G4RFD4266 32GB DDR4 2666 MT/s (PC4-21300) CL19 ECC Registered - Boot screen shows (DDR 2400)
Samsung 970 EVO 1TB NVMe M.2
GEFORCE GTX 1080
Fully water-cooled
Tried the M.2 on both the M.2 slot and on a M.2 PCIe Adapter.
All the compatibility websites I've used says that it's all compatible but I don't know why it it won't work properly.
I had Windows 10 Enterprise installed and then Windows 10 Pro.
16 minutes ago, WorldBreaker said:
Windows 10 Pro.
Random BSoD errors point to bad (or incompatible) RAM.
Run MemTest86 for a number of hours, see what happens
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
This.
Really, the only possible causes are memory or the CPU being Engineering Sample, not a Retail product. It's not guaranteed to be stable in every board/situation.
Are the parts new? Were the CPU sockets fine, no bent/broken pins?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Well I tired of each ram, with just 1 CPU before, I had thought it was the CPU and bought a replacement Intel Xeon E5-2698 v4 ES, but the problem still persisted.
I just bought 4x Micron 8gb Ram PC4-2133P-R DDR4 2133Mhz Reg ECC MTA18ASF1G72PZ-2G1A2.
Hopefully it was just and incompatibility issue but I need to wait till Wed 19 Feb to find out.
All my parts are new other than the CPU, all the sockets are fine no bent/broken pins, had my first board replaced by ASUS themselves but because I was impatient and Asus was taking there time I bought a second motherboard just to make sure.
I will keep you updated when the new replacement ram comes and if you have any other suggestions, I will be glad to give it a shot.
So the Ram I bought were-
  • Micron 8GB PC4-2133P-R DDr4 2133Mhz Reg ECC DIMM MTA18ASF1G72PZ-2G1A2
x4
Totaling to 32GB DDR4
They came Early and like I said I would post an update.
Still same problems can't install windows 10 at all, I keep getting Blue Screen of Death or my system just resets, tried with 3 different Windows 10 downloads on 4 different USB's, and the Official Windows 10 USB that I bought. Nothing seems to working, I need some help please.
I've tried-
  • Windows 10 Pro (Downloaded copy as well as an Official copy),
  • Windows 10 Pro N (Downloaded copy as well as an Official copy),
  • Windows 10 Enterprise (Downloaded copy)
