Search In
  • More options...
Find results that contain...
Find results in...
Headphones or earbuds (wireless)?
A while ago I made this thread regarding the best pair of wireless headphones for around $60-80 (CAD), and the best (and kind of only) suggestion was the Sennheiser HD 4.40s. However, they were actually above my price range (so I never actually bought them) and I'm beginning to wonder if the sound quality improvement that comes with having headphones rather than earbuds would be worth it with such a "low" price-range. Wireless earbuds would be much more convenient for me as I would use them out and about a lot, but I decided to go with headphones since (at a given price) they generally have better sound quality, I also find that earbuds generally don't fit my ears very well, but that said, I haven't tried many of them. Like I said though, maybe with a budget of $60-80 CAD earbuds might offer good enough sound quality that it wouldn't matter too much.
What is actually supposed to go here? Some people put their specs, others put random comments or remarks about themselves or others, and there are a few who put cryptic statements.
Back in the 2000s there was a point where both expensive and cheap earbud makers were using Mylar cones which wore out in a few months and the solution then was to buy the cheapest thing you could because fresh cheap cones still sounded better than worn out expensive ones and if a set of earbuds was basically disposable in months anyway why spend extra money.  I don’t know if that is still the case though.
I sure hope that's not the case. I don't want to spend $80 on wireless earbuds every few months, surely they've thought of a better way to do that now considering you can buy earbuds with prices in the 100s of dollars.
I really really really do NOT like earbuds because they can never stay in my ears and they always keep falling out.
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
totally feel you on that one.
That is why I like headphones much more than earbuds!
  • My system specs
  • ROG PG279Q
  • ROG Sica
Earbuds are easier to carry around though.
Can you imagine what baby today headphones would have to look like though?  Big zucchini shaped things.
Earbuds or in-ears? Currently I only own earbuds that are not in-ear and to protect them to use them longer, I even applied foam. In-ears are also horrible for hygienic reasons. But now I got headphones, my life has become much better.
On 2/9/2020 at 5:42 AM, CTR640 said:
Earbuds or in-ears?
Aren't they the same thing?
  • My system specs
  • ROG PG279Q
  • ROG Sica
Not sure? Aren't earbuds like this:
In-ears goes into the ears which are not comfortable for me.
The qcy t5 is supposed to be a really good cheap tws iem
Feel free to send me a DM for further or general questions.
Lyrics I vibe with or just funny right now:
"This is food for thought, better take the whole plate
Don't lie, some of y'all thought food for thought meant taking these hoes on a date"-Injury Reserve
"Some of em just need to eat a whole thing of Crest"-MF DOOM
"Is it me bruh? (Is it me bruh?)
Am I a bruh? (Am I a bruh?)
Am I that bruh? (ouu)
Eating cactus (peyote)
I looked in the mirror (ya ya)
I like what i saw (that's a handsome boy)
Cuz I saw myself (hey)
And i was the bruh (the bruh)
I am not LeBron (LeBron)
But I am the bruh (the bruh)
I have seen the bruh (the bruh)
I have reached the bruh (the bro)
Why am I a thing? (ayy)
Why do things exist? (why)
All I am is bruh
Bruh is all there's left"-Hovey benjamin
Yeah and you still have to put those in your ears that's why ear buds and in-ears are the same I think.
  • My system specs
  • ROG PG279Q
  • ROG Sica
Wireless i'd go with airpods, but for gaming you should have cable, its a little bit annoying but gives better sound quality, most of the time.
and i'll still use airpods instead of headsett, headset wireless, never been a huge fan honestly.
I think most people that say in ears are referring to ones that go into ear canal.
MacBook Pro 16
i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME - many dongles
Yeah, a bit confusing. I thought this type is called in-ear:
Exactly.
Even our webstores have them sorted into in-ears and earbuds.
Aren't Airpods around $150 or something? Even so, I don't have an iPhone and I believe there are a few problems with using them on Android. I don't plan on using them for gaming so that's not really a concern. The headphones I was looking at originally had an aux input incase I wanted to use them that way, although from the reviews I saw, I gather that there is no sound-quality difference between wired and wireless.
AirPods are Bluetooth speaker one would assume that there wouldn’t be a hardware limitation from using non Apple hardware.  It would have to be a software limitation if there was one and it would likely have to be deliberate.  I can’t speak to the cable-no cable thing.
