Search In
  • More options...
Find results that contain...
Find results in...
is it safe to use port for rgb
i connected msi led strip to my motherboard which has no rgb header(h110m-c/ps)
i think led is 12v (written in manual) and the port i connected it to is chassis_fan(written on top of it)
is it safe to use?
its connected and has red lights idk if red light is not that much because of low voltage or its actually supposed to be like this
i think led is 12v (written in manual) and the port i connected it to is bassis_fan(written on top of it)
is it safe to use?
If it’s not an RBG header... how did you even connect it?
if it’s a fan header, what is likely happening is your providing whatever channel the fans 12v pin is to that channel or RGB. If it’s lighting up red, I assume 12v is going to red, and ground is actually (and luckily....) going to ground. Plugging random wires into random plugs is never a good idea. You can easily end up shorting things out.
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - Steel Series QcK XXL
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: ESXi 6.5 - - 250 GB SSD for VM's/ESXi boot - - FreeNAS - - HPE Proliant ML10 Gen 9 backbone - - i3 6100 - - 28 GB ECC - - 10x4 TB WD Red RAID Z2 - - 10TB WD Red for expendable data - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander
White Lightning (original full watercooled build) - Homelab / Media Server - The Blue Beast (my car and other expensive hobby...) - iPhone Xs - 2018 MacBook Air
is it safe to use?
u can't connect rgb strips to fan headers as LIGISTX said
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
but umm its working idk how(im trying to send a pic using imgurl which i took today )
also it plugged in pretty easy no pressure
still not a good idea though...actually fried a strip of mine once when I plugged it into a fan header instead of a rgb header by accident
Is it an RGB strip, or a LED strip?
Current in process build: Project Odyssey - Build Logs - Linus Tech Tips
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Ryzen Rig 3: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler in push/pull, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.  Lenovo 27" 1080p 60hz placeholder monitor, generic mouse, generic keyboard.  Still a work in progress
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Ryzen Rig 2: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) 3600mhz V-Color Skywalker (or 4x8gb DDR4 2666mhz for large tasks), Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.  Zalman K600S keyboard, Zalman ZM-GM1 mouse, Viotek GN24C 24" 1080p 144hz curved and Hannspree HF207 as 2nd monitor
https://www.3dmark.com/3dm/37004594?
Ryzen Rig 1: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire R9 Fury Tri-X Nitro 4gb HBM, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case.  Zalman K600S keyboard, Zalman ZM-GM1 mouse, Acer XF270HU 2560x1440 144hz IPS monitor
https://www.3dmark.com/3dm/37628874?
Dell OptiPlex 3040 MFF: Dell 0MGK50 A02, i3-6100T, 2x4gb DDR3 1600, Team Group 120gb SSD, 500gb Seagate 7mm HDD attached storage, Windows 10 Pro, Logitech K400+, USB Wifi adapter all vesa mounted to the back of a 37" 1080p TV
Linux Box: Toshiba Laptop, i7 620M, NVS graphics, 4gb ram tinker toy at the moment.  Running Manjaro XFCE at the moment.
Home Security: ZOSI 8 channel CCTV (4 used at this time, 1080p) DVR H.265+, 3tb HGST Enterprise HDD, ASUS monitor for display
https://ibb.co/PD33Bpm
here is the link
is it a rgb or led strip as Tristerin asked?
i was using a deep cool white colored strip with psu connector but someone gave me this one and i was bored cuz of that white strip and my board had no rgb headers
is it safe to use?
if im getting this right you stuck a 12v led strip in a fan header.
ok lol sure whatever floats your boat that will probably be fine. red light could just be the voltage its sending out but i mean you aint really changing that are you XD
if its working nothings gonna break.
as i saw in yt and manual itself its rgb but i cant really control the color because its not connected to the right hewder so i use it as led
Image result for fan header"
was it that sort of header u plugged it into?   (the blue circled one)
when i was building this pc i had a very little moeny and im leaving in iran so everything is like 3-4 times more expensive so i had no choice to get a h series board
no
ok so let me explain a bit
it looked like a 4 pin but one of the pins in middle left was missing(i touth my board is broken but i searched for model and it wasnt)
so it was a 3 pin actually
1 minute ago, BardiaMGTGC said:
no
that's normal on some boards....some only have a 3 pin header
the port that u showed isnt on the board that i have cuz i borrowed someones rgb and had same connector and i searched for it on the board and i wasnt on there
that board doesn't have a rgb header
ok so at last
is what i did fine?
i mean it wont kill anything or catch on fire or anything like that right?
ok so at last
is what i did fine?
I doubt it would catch on fire or kill anything tbh
The holes on a RGB cable is a lot smaller, the pins on the fan header are way too big for it.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
so this msi strip had diffrent headers? it was much bigger than the headers Ben17 sent
Most likely, as the actual RGB header is way too small to fit into a regular fan header.
In this image the pins for the fan header located to the right of the RGB header (circled in RED) is a lot bigger. I just purposely tried to plug a RGB cable into a fan header, it won't even fit.
AMD ThreadRipper 2!
the one that i connected it to looks kinda the same but the name is chassis_fan and it fit easilly with no struggle
35 minutes ago, BardiaMGTGC said:
the one that i connected it to looks kinda the same but the name is bassis_fan and it fit easilly with no struggle
Then what MSI has most likely done is converted to fit into a regular fan header and it's running off the 12v, because some RGB are 5v and plugging a 5v into a 12v header will fried the cable the moment it's turned on.
AMD ThreadRipper 2!
