570 Idle Temp Just Went way up With No Changes
Solved by tsiturbotsi,
Update:
I figured it out. I went into my Radeon Settings and turned on all the game streaming stuff. I just went and turned them all of and the fan spun down immediately and now my GPU temps are back to 22C. Sorry to bother you all with such a stupid thing but maybe this will help someone in the future. Thanks again for all your help.
decolon ·
Posted in Troubleshooting5 -
Rostovne ·
Posted in New Builds and Planning2 -
2
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
