Wich motherboard and fans should i go for?
arnekick
Hi the idea of the build is to be as silent as possible on air cooling. This is my build so far.
Should i go for the Silent wings 3 15db? Or the High speed ones 28db wich i think you will be able to hear pretty clearly. But them have 600rpm more.
Also what motherboard should i go for the aorus master?
Thanks in advance!
Strix-e or taichi are as good as the master for $100 less. And yes, go with the silent fans. The noctua dh-15 is even quieter than the dark rock 4 pro.
