Wifi speeds doubling front port vs back port?
K i a r a
Hey!
So, all the sudden I've gotten a huge drop in download speeds with my back port.
I use a USB Wifi adapter and I've been using it for 3-4 years with no issues till all the sudden. (Back USB port)
Ive tried to use different ports in the back but its no help.
Plugged into my back USB Port.
Plugged into my front USB Port.
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
Added anything to your setup recently that would cause interference with the wireless signal?
Have you moved your PC or your router, or added or moved stuff around either the PC or the router? If so, it's most likely just that the signal has to go through too much stuff when plugged into the back.
Is this a 5GHz network or a 2.4GHz network?
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
8 minutes ago, Den-Fi said:
7 minutes ago, WereCatf said:
Yeah, I moved it across my room. Like 6 Feet.
Its strange because this is the location I first had my setup a year or so ago. And never noticed any issues with the Wifi but now you can tell when you are downloading something that its a big difference.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
5GHz.
M Y  S T U F F
M y  R e v i e w s
More Coming Soon...
There you go, then. Either move it back or use the front-port.
On 1/24/2020 at 4:25 PM, K i a r a said:
5GHz.
5GHz is EXTREMELY easily affected by anything in the way of it's signal. A semi-metal or fully metal computer case is definitely going to affect your speeds like this.
