3800X is hot
Solved by SpookyCitrus,
9 minutes ago, Baron623 said:I'm planning on making a design on the front panel and that should also give it some more room to breath as well. I'll try some changing the thermal paste as well. I have a new tube on hand.
Make sure the mounting is correct and has even pressure across the whole chip, also if your rad and intake fan for the AIO are on the bottom move them somewhere with better airflow on the side or top of the case so it's not obstructed by the floor or in a tight spot to be pulling air in or out, Jayztwocents made a video where he goes over the thermals of the shift and sets it up to get the best temps possible, don't remember which one it is but it's a more recent video from a couple months ago.
