Question regarding Ramsta 8GB DDR4 2666Mhz single stick Overclocked. Luck or dumb move?
Solved by Guest,
That memory doesn't even list an XMP profile. Ouch man.
Get what you can from it. CL18, if it works, stick with it. If it'll do 16-18-18 all the better.
Set only one timing at a time and test for stability at 3200mhz. Just get the timings tight as you can at this speed.
1
1
3
3
1
Fluffy411 ·
Posted in Troubleshooting0 -
SumanRao ·
Posted in New Builds and Planning1 -
1
6
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
