Search In
  • More options...
Find results that contain...
Find results in...
i7 - 8700k Clock speed fluctuating constantly
Go to solution Solved by Lurick,
Just now, Im_Ben said:
The power settings is set to high performance in the bios, if that's what you meant?
In Windows itself, under the Power Options > Change Plan Settings > Advanced Power Settings > Processor power management
I have overclocked the 8700k to 4.8GHz on all cores, and the AVX is set to 3. The core speed fluctuates a lot when it's idle. However, when I play games, it goes to 4.8GHz. So what's happening?
Cpu under load:
Cpu when idle:
Cpu -z
Intel Speedstep is on I believe which will adjust the frequency low or high depending on the load.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
That is turned off.
Then it's not obeying the setting / there might be a 2nd one.
F@H
Desktop: i7-5960X 4.4GHz, Noctua NH-D14, ASUS Rampage V, 32GB, RTX3080, 2TB SX8200Pro, 2x16TB Ironwolf RAID0, Corsair HX1200, Thermaltake Overseer RX1, Samsung 4K curved 49" TV, 23" secondary, Mountain Everest Max
Dell XPS 2 in 1 2019, 32GB, 1TB, 4K
GPD Win 2
the other other thing I can think of is for OP to check power settings and make sure minimum processor state is set to 100%
Prior Build Log/PC:
If there's a 2nd one, I can't find it in the settings.
Prior Build Log/PC:
Honestly if you are going with 4.8ghz...you are better off enabling MCE and turning up the clock to 102.9...setting AVX to zero....this gives you ~4.836ghz on all cores that run in perfect harmony...this is what I've done just cause my system runs so well at those settings.
That seems to have fixed it. Now it's at 4.6Ghz(ish) due to AVX offset.
Thanks for the help though!
Just now, Stu_Bear said:
Honestly if you are going with 4.8ghz...you are better off enabling MCE and turning up the clock to 102.9...setting AVX to zero....this gives you ~4.836ghz on all cores that run in perfect harmony...this is what I've done just cause my system runs so well.
The problem is fixed now, but I'll try out your settings and see if those are better.
 Share
