Stock vs Corsair fan positioning
ernie mills
Hi, I was hoping to get a piece of advice for my airflow layout. I have an NZXT H510 case which comes with two exhaust coolers (top, rear). I also purchased two corsair ML120 fans for intake (I know this case is designed for negative pressure but I didn't want dust getting sucked in from every orifice). Given that this case prioritizes negative pressure, should I use my nicer fans as exhaust and use the stock as intake? Essentially keeping the positioning the same for all the fans just switching the exhausts with the intakes. Or does this not matter at all?
Thank you!
CPU: AMD Ryzen 7 3700x  ~  Case: NZXT H510   ~  GPU: Gigabyte Radeon RX 5700XT Gaming OC   ~   RAM: 4x8 GB Corsair Vengeance (3000 Mhz @ 15 CL)
Motherboard: MSI B450 Tomahawk Max   ~   PSU: Corsair CX 650M   ~   Cooling: Corsair ML120 Pro   ~   Storage: Adata 512 GB NVME SSD
I personally would use the two ML fans as intake (good choice), and use the one stock fan as exhaust, this will ensure positive airflow.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
I understand wanting to achieve positive airflow I was just wondering if it makes any difference using the nicer fans as exhaust vs intake since there will be 2 in and 2 out no matter what.
I don't think so. The ML fans are probably better optimized for static pressure than the stock fans, meaning they are better for intake fans so they can fight the front panel for airflow, doing a better job than the stock fans. Makes more sense in that config.
My Builds:
MEGA Desk Build
Great, thanks for your replies!
No problem!
Watch this LTT video on airflow, it is one of my favorite!
My Builds:
MEGA Desk Build
I would use the ML ans intake and stock fans as exhaust.
The ML fans are overall a much better fan with more performance than the included Aer F120 fans.
ML120 have a much bigger rpm range 400-2400rpm with higher flow and pressure.
Compared to Aer F120 500-1500rpm.
And the ML are more quite (unless you crank them to 2400rpm ?
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: In Win D-Frame   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
Try it out and see. It's hard to tell how the system would actually perform due to how complicated airflow can be with the unique obstructions involved.
