200€ 144hz Monitor?
Donki Knog
I'm looking for a 144hz/165hz monitor for around 200€, but I have no idea of displays, I was looking for a Zowie, but, I don't know if there is better options for this price.
I want the monitor mainly for shooters.
Most TN 1080p 144hz ones are fine at that price point.
I have an AOC one and its brilliant, its also freesync.
i5 8600 - RX580 - Fractal Nano S - 1080p 144Hz
Are you buying in dollars? If so, what kind?
If you're not, there's no point in quoting pricing other than what you're purchasing in.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
No, in euros. I used dollars because most of the times they do a 1$=1€, so, it's almost the same.
Yeah, but pricing isn't at all the same. Nor is product availability.
It doesn't make any sense at all to get US pricing for what you're buying.
Changed!
16 minutes ago, Stephen Planz said:
There is an ips 144hz monitor from acer that’s amazing it’s $199
Acer Nitro VG240Y https://www.amazon.com/dp/B07VFPYRP3/ref=cm_sw_r_cp_api_i_e95eEbN3JQZX0
I only can find the 1440p version in Spain ?
Just now, Donki Knog said:
Changed!
I only can find the 1440p version ?
Did you copy the link
In Spain I mean.
