ok need help i9 9900k or 3900k
Go to solution Solved by Mister Woof,
2 minutes ago, tommy3010 said:
mmmm so not go for 64 gb
Usually will work perfectly fine. Sometimes need to run a bit slower than advertised speed. Very rarely does not work at all.
Decent chance needs a little fiddling with to get it running perfectly smoothly, though.
i will be gaming ie apex, fortnight, bf
plus i will be using Photoshop,illustrator,after effects and more
and also will i need special ram for the amd cpu
3900k
It's better at anything with high threads.  Special ram? Not really, but if you're worried pick something off the motherboard QVL list, otherwise just find a kit of DDR4-3600 with CAS 16 and you'll be set, can just turn on XMP and be done.
3900x; 50% more resources and same price
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
some say amd not stable and get lot of problems or is that in the past
Had more issues with my Intel systems than AMD ones.
They typically have more issues with BIOS, RAM compatibility, and longer POST times vs Intel systems.
In my experience this is true, but it is fixable and not enough to warrant dismissing their blatant advantages.
Cue the fanboy rage
so ram i hear alot about it was one thing that sort of made me think not amd am no pro and dont need to be forever fixing just want to play and work lol was going to get 64 gb any thoughts on what one
More ram sticks is more difficult for the integrated memory controller to handle (this goes for both Intel and amd), it's just more potential for conflict with the preexisting teething issues Ryzen has with bios/ram.
I have a Ryzen 3900X + X570 Aorus Xtreme + 4X 8Gb DDR4 3200, built this rig in early August and have had no issue whatsoever. Gigabyte Bios updates have been pretty good actually so get that combo that you've been eyeing with confidence.
Main Rig: AMD AM4 R9 5900X (12C/24T) + Tt Water 3.0 ARGB 360 AIO | Gigabyte X570 Aorus Xtreme | 2x 16GB Corsair Vengeance DDR4 3600C16 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Topre Type Heaven + Seenda Ergonomic W/L Vertical Mouse + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 3900X + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Keychron K2 + Logitech G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
I think that buying that kind of cpu is more than a tad overkill if your main games are Fortnite and Apex....
I9 / 3900x are workcpu's not hobbygaming imo.
Here is also doing some productivity stuff that would likely benefit from the extra threads.  Also newer games are starting to take advantage of those extra cores more and he isn't going to be playing Fortnite and Apex forever.  What about new games coming out 3 years from now for example?
Still I get your reasoning, with current games, the difference between a 3900X and a 3600 is minimal, probably like 5-8% in performance and you can buy 2.5 3600 processors for the price of a 3900x.  It really all comes down to how much you think your going to be relying on those extra cores now and in the future.
