Hi could i get some help
Numbal
So am buying a new laptop and are wondering how much of a difference does 1000MHz make its between the NVIDIA GeForce GTX 1050 Ti Max-Q at 7000MHz and the NVIDIA GeForce GTX 1650 Max-Q at 8000MHz. Also it seems that the NVIDIA GeForce GTX 1050 Ti Max-Q has a higher MHz boost than the NVIDIA GeForce GTX 1650 Max-Q. The difference of price between the laptops are $175.
Thank you very much for any help ?
You want the 1650.
The 1650 will be massively better than the 1050 Ti.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Don't look at clock speed to determine which is a better option, look at proper benchmarks.
The 1650 is about 10-30% percent better depending on the game we're talking about .
Whether that difference is worth the money to you, is your personal decision
