3000Mhz RAM running at 2133Mhz
Solved by minibois,
1 hour ago, OKBruh said:When i go to bios it shows me load xmp on auto and dram frequency on auto do i change my dram frequency on 3000 and load xmp setting on xmp 2.0 profile 1 ??
You don't need to update the BIOS, unless you're experiencing issues.
I would honestly just set it to auto.
It's possible it needs to 'train' the memory. What that means for you is that after setting the speed, it might restart the PC a couple times. That is normal, it is seeing what works best.
