Dual Monitor Settings for Nvidia/Intel
Hey all,
I've been dropping frames and had... weird issues when playing games (the game will freeze when accidentally moving the cursor to the other screen). Nothing super major, but wanted to see if there's anything I can do to fix it. do both monitors need to scale through gpu? physx on cpu or gpu?
https://linustechtips.com/topic/1135826-dual-monitor-settings-for-nvidiaintel/
Are you playing on full screen? Default nvidia settings work perfect with multi monitor. Unless you play windowed, that’s normally where the issue comes from.
I'll need to check. it's not just the one game though. several games i usually don't have issues with. also, does it matter that they're both 144hz?
