looks like the mobo that was recommended was from someone that didnt know anything about mobos
see mobo here
so i have to redo the mobo pick
what is an equivalent of that mobo that is a small size?
requirement for best mobo:
1. small size, any of the small size seems to be fine
2. fits these parts
3. easy to put together
4. not excessive beyond what is actually needed
5. anything else that is important, ppl that knows about pc building, and are informed on best parts should know what is important
https://linustechtips.com/topic/1135743-best-small-mobo-redo/
* thread locked *
You already have a thread asking about that, please keep the thread alive if you want answers. Creating multiple threads asking the same question is considered spamming.
https://linustechtips.com/main/topic/1133718-mobo-have-finally-found-all-the-parts-and-now-need-the-best-mobo/
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1135743-best-small-mobo-redo/#findComment-13142886
Guest
