best power supply for this first & last build?
these are the best items that has been recommended for this first last build
  1. mobo = b450 tomahawk
  2. cpu/gpu = amd 2200g igpu
  3. ram = going for 16 or 32 or 64 ram, doesnt seem like anything about ram really matter besides the amount
  4. ssd/hdd = any ssd or hdd would do (there has not been any good tests or analysis from anyone that ssd is any faster than hdd for using youtube, or using chrome)
  5. mini-case = case is decided after right?
what's best power supply for this?
just link with basically why its best
https://linustechtips.com/topic/1135663-best-power-supply-for-this-first-last-build/
3 minutes ago, win10user10 said:
  • ram = going for 16 or 32 or 64 ram, doesnt seem like anything about ram really matter besides the amount
  • ssd/hdd = any ssd or hdd would do (there has not been any good tests or analysis from anyone that ssd is any faster than hdd for using youtube, or using chrome)
First off all 16gb is enough for normal use (gaming etc.) , and you completely wrong about it, ram speed is really important with Ryzen cpus, specially if you planning to use igpu, faster ram is much better in that instance. Also important is dual channel which benefits cpu greatly. Not sure where you get this info from tbh.
SSD is faster even when accessing normal applications, not even mention booting times. Do your research again maybe if you don’t believe me.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
no you need to choose a case to know what size of power supply it supports...most mini case require small form factor powersupply which are more expensive..
this should fit in anything though:
https://pcpartpicker.com/product/V3ndnQ/seasonic-focus-sgx-450w-80-gold-certified-fully-modular-sfx-power-supply-ssr-450sgx
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
