why even Intel when you're on a budget
they are both poor for more than an i5
Desktop benching:
If you’d bought your cpu, go with the asus prime, I see 2mmore capacitors which will add like 0.0005% more performance in OCing
if you haven’t bought your cpu yet, go with amd, they have better value motherboards and cpu at this time in the low end.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
3 minutes ago, Ad18o said:
I was thinking of upgrading to an i7 or i9 after a couple months
I should mention that neither of these 2 can OC a i9
What CPU do you have at this point?
F@H
GPD Win 2
You said "the oc capability is for my i5 before i replace it"... so what i5?
F@H
GPD Win 2
10 minutes ago, Ad18o said:
I understand Amd is better for budget however i will prob upgrade soon, i dont wanna lock myself into amd when high end intel appears to peeform better
But the new intel cpu are going to need another motherboard. They confirmed the z470 motherboards for the 10900k already. So why buy a motherboard for a cpu now that you cannot use in the future?
Yup the upgrade makes no sense. Would cost a lot for a small upgrade to an already good system, and it's all into a dead platform.
F@H
GPD Win 2
True, would u reccomend any amd board
A b450 + r7-2700x combo should run you about $250, and with a bios update, you can enable ryzen 3000 support, so when ryzen 4000 comes out, and if b450 doesn’t support ryzen 4000, then you can snag a discounted 3000 cpu and reap a ton of cost savings. If you’re looking for game performance, 95% of that comes from the gpu, so look for a better gpu instead of the most over the top cpu.
Is the 5700 xt enough
Enough for what?
That was a bad question, is it an adequate gaming gpu or should i go with a 2060 super
The 1650 is an adequate gpu for gaming, but are you aiming for 1440p? 144hz? Ultra settings? 1650 is not going to do that. The recommendation is always to spend the most you can, because future proofing is a lie, but you want the most you can get now.
with the 5700 xt, you’ll be able to play a lot of games at 1080p 144hz ultra, or maybe even 1440p 60hz high. Especially paired with the 2700x you should hit around 120-144hz in cpu intense esports titles. These are stuff you know for yourself.
The only information I have is that you want to game, please give me both your budget and goal, and I’ll try to steer you in the right direction.
37 minutes ago, Ad18o said:
Yeah, ik, the oc capability is for my i5 before i replace it
can you get a Gigabyte Z390 UD?, its basically the only budget Z390 worth even trying to OC with a i7 or i9
Sort by prices looking for "Ryzen 3000 Ready" boards on retailer of your choice website, see what you can find that references well against this list
https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Stuff like MSI Tomahawk MAX, MSI Mortar MAX, ASRock B450m Pro4, ASRock Fatal1ty B450 Gaming K4, ASUS Strix b450/x470, stuff atleast rated for 100A on that list are decent minimum to getting into AM4, support stock 12 core no problem and overclocked the 8 core parts with those, no problem.
if you want something that will eventually be overclockable for 16 core part on a budget honestly its best to just go to x570 and go with Asus Prime X570-P as all the b350-x470 boards as capable as it cost more, atleast in NA and so far as im aware.
My goal is to play ultra setting on pretty much every game at 60 fps plus
These are the builds im trying to decide between
And
The monitor is shared
Go with the amd build, but there are some parts that are more expensive that have the equivalent performance on the intel side like ram and storage, that’s probably why it’s $200 more
Its because i included the monitor on that one, they are both within 5$ of eachother
Oh I didn’t notice the monitor, the amd one is $400 cheaper then
