Will my ASUS Prime B450-m-a work with 4 cpu power pins?
Go to solution Solved by KingTdiGGiTTy,
Since the 2400g is pretty low power you probably won't have a problem using an adapter, though its a bit sketchy.
It would be better to have a decent PSU.
4 pins (1 connector) supplies 155W. 8 pins (2 connectors) supplies 235W. You should be more than fine as the 2400G is rated at 65W.
Credit to @i_build_nanosuits
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
Just now, KingTdiGGiTTy said:
If the pins fit I do believe it will work, however that's the kind of sketchiness I reserve for PCs built using used parts.
Standard 8 pin power connectors are half a standard 4 pin, it's not sketchy since it's the same design
Primary PC:
Yeah but if your buying a new motherboard, but your cheap PSU doesn't have an 8-pin, you might be better off buying used.
