Hello everyone,
I looking to buy tv, but there are too many options and it's hard for me to decide. I will be using it for Netflix (4k), YouTube, Spotify, etc. mostly i.e. streaming media from my phone.
After looked into a couple of options and I felt the most appealing one is buying a budged 4K no-smart TV, with nice display (obviously the most important thing) and getting a Chromecast Ultra.
Read about Mi Box and comparison vs the Ultra, and it seem like if you are going for 4K the chromecast is the correct choice.
There are also TVs with Android TV that support chromecast, which makes the decision even trickier...
What do you recommend for my case?
https://linustechtips.com/topic/1135152-smart-tv-or-non-smart-with-chromecast/
pretty much all tvs are smart tvs (except scepter)
there are other smart tvs that support chromecast besides android smart tvs just have to look at specs. its up to you which will work best for you... all built into tv or using a external device. (i use both so and they both work same for what i use it for)
