Affordable monitor for creative work (3D,Art,Gamedev)?
Hi there.
Does anyone know of a good but affordable monitor for creative work (3d modeling/game dev/art) with a good display?
I'm wondering if 4k is worth it, and im not really playing games anymore so I think I'd be willing to give up high refresh rates.
It's really not, you can find cheaper 1440p monitors that will get the job done just as good and without weird UI scaling issues.
up to 4k only starts making some sense on 32inch screens so if you're thinking on 27 inches 1440p is golden.
About what screen, you'll likely be fine with any IPS at 60hz~75hz you can find.
Personal Desktop":
Luna, the temporary Desktop:
Haven't really thought of the scaling issues. Would 4k at 27 inches be hard to look at with the scaling set to 100%? I've tried 1440p at 27 inches at 100% and it looks great so maybe I'll go for that.
Oh yes, it's impossible to use 4k at 27inches on 100% scaling.
Personal Desktop":
Well that's good to know! I guess 32 inches+ makes more sense then if I absolutely want to go 4k.
I want to stay at 100% scale, so I'll take this into consideration when looking for monitors from now on. Thank you!
A 34" 1440p ultrawide is also a good option if you need more horizontal space. Otherwise normal aspect ratio monitors are better, also easier to fit on a desk.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
I watch a lot of movies/shows/youtube, so I've kinda scrapped that idea because the thought of black bars on the sides would be annoying. And yeah space, I like having two seperate monitors.
