Motherboard HDMI port not working?
Go to solution Solved by GDRRiley,
yep that internal graphics one is it.
I recently upgraded my PC with a used Gigabyte H370 Aurus Gaming 3 Wifi motherboard. I have my NVidia GeForce GTX 1050 Ti installed, to which i have both monitors connected, one by HDMI and the next by display port. When i tried to connect either of the monitors to the motherboard's hdmi port no input was detected. Is there a way to make it so that i don't have to rely solely on the graphics card?
https://linustechtips.com/topic/1133641-motherboard-hdmi-port-not-working/
I think you can't have both GPU and Igpu drivers installed and work.
It's either the one or the other.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Bios setting to enable both to run.
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
i tinkered in the bios and changed a setting from PCIe slot 1 to IGPx, now when i try to access the bios neither monitor displays it.
Before i changed the settings nothing really stuck out
what CPU do you have?
11 minutes ago, DenShazo said:
Intel Core i7 9700k
ok clear the cmos and then look for dual GPU option
it isnt a 9700GK right?
1 minute ago, homeap5 said:
I give you answer (what option in bios you should look for) and you changed different one.
dude be nice they sound pretty close.
Just now, DenShazo said:
Thanks for the walkthrough :)
welcome. I remember struggling on my 6600K to do it.
Well my new ryzen chip will end that
4 minutes ago, DenShazo said:
Here's to these things becoming easier to find down the road
give it a few years. I'm now 6 or 7 years into PC building. While my main system is about to celebrate 4 years. 2 years with a 970 then 2 with a 580 from a member give away here. Upgrade time is coming, NightHawk will be rebuilt to NighHawk 2.0
My 5 year old 5960X build will probably find itself ousted by a TR3 build next year :)
F@H
GPD Win 2
