Hello
im new to this pc building stuff this what I have but don’t know if the 550w 80+ psu is the right size could any one help please ?
Asus rog strix x570-f motherboard
amd ryzen 9 3900x
4 x 16gb vengeance rgb pro 3200mhz
Asus GeForce rtx 2080 ti
2td ssd
480gb m.2
WiFi + Bluetooth pcie
Corsair hydro h100i rgb platinum
4 120mm rgb fans built into case
https://linustechtips.com/topic/1133322-what-power-supply-do-i-need/
Technically yes, but most good PSUs cost almost the same for 550W and 650W versions. You don't choose a PSU for it's wattage alone.
Refer to this thread for advice in choosing one :
Where are you from ?
Tag or quote me so i see your reply
Do you have a PSU already? Do you have a specific model number, please? There are very good and very bad PSU's, regardless of wattage and 80+ certification..
A system like this will probably use around 500W at full (overclocked) load.
https://www.guru3d.com/articles_pages/amd_ryzen_9_3950x_review,7.html
https://www.guru3d.com/articles_pages/msi_geforce_rtx_2080_ti_lightning_z_review,8.html
I would only really recommend a very good 550W, but would rather suggest a higher wattage model.
Something like the RM650X/750X, Be Quiet Straight Power 11 650W, etc.
(See the thread posted above for more PSU options)
It’s a thermaltake tt 550 says it’s entry level one in there website
As a general rule of thumb, you don't want an entry level PSU for the highest end components on the market..
But it looks like Thermaltake has quite a few models, in different tiers too.. TT is just an abbreviation of Thermaltake, would you happen to have a more precise model number?
Or do I just do the asus rog 800w then it’s future proof?
Asus ROG Thor 850W?
https://www.asus.com/Graphics-Cards-Accessories/ROG-THOR-850P/
Sure, good PSU. (There is also a bad PSU called Asus ROG Strix, which is why I asked this).
You could get a Corsair RM850i for a similar experience too.
14 minutes ago, minibois said:
Asus ROG Thor 850W?
That’s the one I’ll go for ?
Yea that will work good. It's just that you can get an RM850i for 90 GBP less
https://www.scan.co.uk/products/850w-corsair-rm850i-series-fully-modular-psu-80plus-gold-certified-135mm-fan-atx
But just depends on how much you value the RGB and such.
That’s going to be the one the asus one out of stock till the end of the month
