SysnativeFileCollectionApp.zip
I have attached my sysnative file that has most of my BSOD data in it.
More information, this has never happened to me while playing at game, its always while it is under light load.  If I do not get a BSOD, I will get my screens to just freeze requiring a hard reset or my screens will go back to 8-bit looking then lockup.
This is a fresh install of Windows 10 1907 Pro
Hardware ranges from old OEM RAM that is 3 or 4 years old to a few months old (CPU, Mobo, GPU)
No overclocks
PSU EVGA 650 Bronze (buying new shortly)
I have unchecked Enable Fast Startup to make sure each reboot was as fresh as possible.
I already have new RAM on order as this was just pulled from a working system to get something slotted
https://linustechtips.com/topic/1133176-random-bsod-lock-ups-and-crashes/
  • Flash your BIOS to the newest revision.
  • Run MemTest on your RAM to verify it's in working order.
  • Download your display drivers from Nvidia's site
  • Uninstall your current display drivers using DDU (before running DDU disable your NIC to avoid Windows auto installing a dated driver upon restarting).
  • See if all that helps, post back either way.
  • 2 weeks later...
On 1/4/2020 at 10:22 AM, 317Games said:
No BSOD since reseating CPU and GPU.
Still no crashes? I'm getting a pretty similar issue happening since building my PC and can't for the life of me figure it out. Haven't tried reseating CPU, so maybe that was the trick?
