Hello all,
I recently just changed my ASUS Z370-F to a ASUS MAXIMUS X HERO, they are both on the same Z370 platform. However, whenever I try and boot into Windows with my previous boot drive, it gives me errors and goes into recovery. Can anyone help please? I don’t really want to fresh install as I have programs and games that I have to reconfigure/install and I don’t have time for that (simply put it, i’m too lazy :P
afaik, changing motherboards and keeping the same platform and boot drive is fine? My SSD boot drive can be accessed fine when I plug it in to my external dock.
I have tried to do start-up repair using a bootable usb drive but that didn’t help. I have since moved back to my Z370-F motherboard and now I cannot even boot into Windows with the same boot drive that worked before, it gives me the same error/recovery page. Is there any chance of getting back my old boot drive or is it completely gone?
EDIT: I have updated to the latest BIOS version and cleared CMOS.
here are the error pictures:
https://imgur.com/a/4rA919e
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Reinstall windows when you do a motherboard change.  Don't cheap out.
Sometimes you can get away with keeping your old files and apps and escape unscathed.  Sometimes it requires a blood sacrifice (windows.old and your documents and settings backed up to an old folder as when I went from a 2600k to a 9900k, I fresh installed windows.  Had to reinstall all my programs but my saved games were backed up by windows into a new folder for the old windows installation).
well, my last resort is a fresh install. i have no other choice, really.
do you know the most efficient and best way to back up my files from my old bootable drive? i want to take advantage since i can still access it via my docking station.
Old Rig
bump
Old Rig
