How to overclock Ryzen 3 2200G Graphics?
I've done a few overclocks on these Ryzen iGPUs. Definitely set them in the BIOS/UEFI, Ryzen Master overclocks on the iGPU are not going to stay consistently and may or may not lose stability from losing other settings through reboots. It shouldn't but it does. I've done a pair of 2200Gs and 3 2400Gs now and every one of them took 1500mhz with reasonable voltages. IMHO, iGPU and then DRAM speed are priorities over CPU speed when trying to use the iGPU for gaming, so undervolting the CPU cores to the lowest stable level at 3.6-3.8ghz(should be doable with 1.1-1.25v, with priority to the lowest stable voltage you can muster over 3.5ghz for thermal headroom), then overclocking your DRAM with a fixed CPU NB/SOC voltage of 1.15-1.175, and no higher than 1.2v for long term should get you a good base to then overclock the iGPU. Bump the GPU to 1.2v and start ramping up the clockspeeds. I've found a veritable badlands of GPU speed between 1375-1450 with none of them stable in that area, no matter what I did, so after the third one to exhibit this behavior to me, I just hit it with 1.2v and 1450mhz out of the box, after the other adjustments to find CPU and memory stability, and work from there. Short therm I've done 1.25v on the GPU and managed 1625hz, but I don't recommend it. 1.2v and 1475-1550 should be in the wheelhouse of basically every 2200G and 2400G.
Memory speed and timings are important, so don't slack there if you really want the most out of this iGPU. 3200mhz cas16 should be the baseline target IMHO and I would take a point off CAS latency instead of 100mhz more memory speed when using the iGPU.
