Dell Audio on any Computer - Will it work?
Go to solution Solved by FlappyBoobs,
What do you mean by the audio software? The popup that comes up when you plug in a headset? That's the only audio software I have on my Dell machine, and it's standard for any machine that uses it.
The software is just Waves MaxxAudioPro
Greetings Community,
I was wondering if there was some way to get the dell audio software on any windows computer as i really enjoy the software. Any Suggestions?
Thanks, Birdflyer
R U L E  # 1   A b o u t   M e:   I   u s u a l l y   g i v e   D U M B   a d v i c e   a n d   y o u   s h o u l d   n o t   l i s t e n   t o  m e.
https://linustechtips.com/topic/1132902-dell-audio-on-any-computer-will-it-work/
