Does a CPU use more voltage/power when in idle?
Solved by Husky,
It is not actually using more power when idle, the voltage is higher, yes, but the actual power draw is less. The reason the voltage is lower when running under load is because there is voltage drop due to the increased power draw. Most motherboards have LLC (Load-Line Calibration) settings to try and combat this since it can sometimes cause instability when overclocking very far.
