Facing problem with image and color quality
Yesterday I bought Viewsonic XG240R. Its a TN panel monitor.
The fact is, I am facing some problems.
The image quality in the bowers on any website showing at low resolution and blurry.
Color deepness is high and It feels like its attacking to my eyes.
How should I calibrate that and fix that problem.
What should be the Brightness, Contrast, Gamma, Black Stabilization ?
https://linustechtips.com/topic/1132615-facing-problem-with-image-and-color-quality/
check TFTcentral and see if there is an ICC profile for your monitor. If not, you will need to get a display calibrator and calibrate it manually.
"Black Out"
Dedicated Streaming Rig
You could try the settings used in this review, HOWEVER note that each individual display will be slightly different. So ICC profiles and settings from one review sample will not be totally accurate for ur display.
https://www.tomshardware.com/reviews/viewsonic-elite-xg240r-144hz-gaming-monitor,6165.html
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
