As manny of you might have noticed I am kind of a compute geek and run Folding, BOIC or my own physics simulation (I work in theoretical physics) crap close to 24/7. I am now getting a 3900x for Xmas. Therefore I need a MOBO wich:
  • 3x PCIe 16x (I need 3 fast GPUs for compute and its best to have them at least at 8x)
  • x570 (want to have future proof PCIe 4.0 since I need to move tons of data)
  • DECENT VRM for OCing 3900x 24/7 (no hardcore OC, I want it to be 24/7 save)
  • CPU/GPUs will be on water but there will be a bit of airflow over the VRM form the case fans.
  • USB-C (TB nice but not needed)
  • Audio solution irrelevant
  • Ok silent Chipset fan or possibility to getto mod a small noctua on there
  • Don’t need WiFi
  • max 300€
My research came to the Gigabyte x570 Aorus Pro. Is this a good choice or would you pic something else?
THX guyzz
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1132190-mobo-for-3900x-near-247-max-cpu-load/
What’s your budget?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
How are you going to have 3 GPUs at 8x on a 3900X?
Personal Desktop":
Luna, the temporary Desktop:
no no i am not. Optimal perf is at 8x but for some workloads 4x is also fine.
With future pcie 4.0 gpus that won’t be a problem anymore.
for extended loads i'd pay a bit more for the master's heatsink, or you'll have to make sure whatever you run doesn't heat up the vrm above 85C (it's fine for regular use but 24/7 i wouldn't keep it at 85C)
I realize the master is over your budget but it's well worth it in ur use case imho.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
GB X570 Aorus Pro $260 like the Ultra but cheaper, the Taichi is better!
ASRock X470 Taichi Ultimate is a cheap way of getting 10gb lan for $260
MSI MEG X570Unify is kinda cool @ $300, ace minus a lan port, removed a lot of the bling, has post code, all around good, the board is ok,not a bad board just get the taichi, the taichi givs you more sata ports
ASRock X570 taichi $280
great board, solid board, asrock bios kinda clunky, fully featured with post code, 12 phase vrm, pwer button, reset button, clear cmos buttom and some on rear io, bios flashback button, does a little bit of everything
so how does the Aorus pro and taichi VMR compare?
would zu run taichi 24/7 under heavy load?
