How to remove a stuck stand-off from a case and motherboard?
Go to solution Solved by Tristerin,
Your case doesn't have a side panel to pull off for cable management to see the stand off?  It should, and Id go from that route and use a sharp instrument to loosen the case material around it to allow it to easily pull free.  My 2 copper coins
Please read before replying with "Just hold the stand-off and then unscrew the screw from the other side". I can't do that.
I bought a Fractal Design R6 and a Gigabyte motherboard, I had to remove one of the stand-offs that came pre-installed with the case because maybe some of you know Gigabyte puts one of their holes in the wrong place. Anyway, I removed it and put it back where it should be and installed the motherboard.
Thing is then I wanted to take the motherboard out to be 110% sure that I there weren't any other stand-offs hitting the board. I checked before like 5 times, but I'm paranoid and wanted to check again.
I'm sure there aren't any stand-offs hitting it, but again I'm paranoid.
Thing is when I tried to take the motherboard out, one of the screws unscrewed the stand-off. Not the one I installed, but the one on the left side, the one where the PCI slots are.
I tried to unscrew it but it kept making noises, like a pop, so I stopped. I tried to take the motherboard out, but it's stuck. So I assume the screw is stuck in the stand off while the stand off is stuck in the case. I can't psychically reach the stand off to hold it in place so I can unscrew it.
How do I remove it? How can I take the motherboard out without damaging it? Do I just have to unscrew the screw which will force the stand-off to unscrew itself and then be careful while pulling the motherboard?
If I understand correctly, a standoff screw is stuck threaded through one of the motherboard screw-holes?
If so, some pliers with a decent grip may be able to force the screw out, but you run the risk of destroying the thread.
i7 6700K @ Stock (Yes I know) ~~~ Corsair H80i GT ~~~ GIGABYTE G1 Gaming Z170X Gaming 7 ~~~ G. Skill Ripjaws V 2x8GB DDR4-2800 ~~~ EVGA ACX 3.0 GTX 1080 SC @ 2GHz ~~~ EVGA P2 850W 80+ Platinum ~~~ Samsung 850 EVO 500GB ~~~ Crucial MX200 250GB ~~~ Crucial M500 240GB ~~~ Phanteks Enthoo Luxe
You mean just grab the screw and pull on it? So basically loosen the screw with the screw driver and then pull on it? Won't that force the stand-off to came out as well? Which may result in damage to the board?
You can latch onto the screw with the pliers and twist it, to force it to come out. It's a very rough method, and almost guarantees the thread becoming unusable later on.
hold the standoff with pliers, either from between the motherboard and case, or from the backside of the case. Then take out the screw.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
YES it does. I didn't even realize this. Thank you so much.
Seriously it didn't even cross my mind.
Rather than loosen the material off the standoff Id try this first
