Im planning on building a PC and have chosen to use an Intel Core i5-9600K processor, but im having trouble finding a motherboard that supports Wifi/Bluetooth for a reasonably cheap price.  If you have any suggestions that would be greatly appreciated:)  Also if "cheap" intel motherboards with Bluetooth and Wifi don't exist, please just recommend the least expensive.  thanks!!
https://linustechtips.com/topic/1132132-searching-for-bluetooth-intel-motherboard/
i dont believe that i have seen motherboards that support both wifi and Bluetooth.  Your best bet is to either get a mobo with wifi and get a bluetooth adapter or get a mobo with no wifi and get a wifi and Bluetooth adapter.  In terms of recomendations, get a z390 mobo and ur set.  Generally the aours mobos can be found for realtivley cheap but are also solid boards
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
Why want a motherboards that is like 50+$ more expencive cus it has bluetooth and a lot of other nonsense you dont need, while a USB BT dongle is like 10 bucks?
And if you wnat this cus the USB BT dongles are shit i can very much inderstand but you might want to look into mini PCIe and their wifi/BT combo cards for that. No need to have special motherbaords.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
Typically boards that support WiFi also supports BT. MSI Z390 Gaming Edge AC?
Desktop benching:
