3 minutes ago, magicammo said:
I normally buy a new case every year to freshen things up I'm looking for a compact ATX case that supports AIO water coolers and decent gpu clearance any suggestions?
Which AIO's? I know of the Sliger Cerberus X and the Riotoro CR1080 which can both hold 240mm rads, or the Cougar MX330 and Meshify C than can both hold 280/360 Radiators.
Lian Li may be working on an ATX version of the TU150 as well.
https://i.imgur.com/rCtt20i.mp4
What kind of AIO are you requiring? Because Corsair made the H5 SF AIO specifically for small cases. If you want something more traditional like a 120mm rad, the smallest case I've seen with one installed is Silverstone's FTZ-01/RVZ-01/RVZ-03/ML-03 (it's basically the same case with different fascias)
I have a Corsair 240mm
CPU: AMD Ryzen 9 5900HX GPU: AMD RX 6800M RAM: 16GB  SSD: 500GB NVME
Riotoro's CR1080 and 1088 are two very small cases that dont break the bank (they have GPU height restrictions though, so AIB partner cards that are extra tall might not fit)
https://pcpartpicker.com/product/kssmP6/riotoro-cr1088-atx-mid-tower-case-cr1088
https://pcpartpicker.com/product/DBjWGX/riotoro-case-cr1080
If you need more space, the Meshify C or the Cougar MX330 are both good options (depending on how much you wanna spend. The big difference is build quality)
That lian li one looks dope but doesn't look like it will have great airflow
I'm looking for compact ATX cases
