Hello so I just upgraded my PC from
EVGA GeForce GTX 1060 3GB and ntel Core i5-7500 Kaby Lake
to ASUS GeForce RTX 2070 and Intel Core i5-9600KF
And I just tried Battlefield 5 but im getting 60-70 fps on low, same as I did with my 1060
What is going on?
https://linustechtips.com/topic/1131650-rtx-2070-not-giving-me-better-fps/
Are you using the same Windows installation from before? You could have issues with drivers and registry entries if the system didn't adapt itself properly to the new hardware.
Personal Desktop":
Luna, the temporary Desktop:
Run DDU in safe mode (program will prompt on launch): https://www.wagnardsoft.com/forums/viewtopic.php?f=5&t=2553
Delete drivers and restart.
Disable windows automatic driver install: https://www.laptopmag.com/articles/disable-automatic-driver-downloads-on-windows-10
Download newest drivers and install: https://www.nvidia.com/Download/driverResults.aspx/154342/en-us
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Would make sure windows is updated and check GPU drivers.
You should be getting framerates like that on high with RTX on, not low.  Something is not quite right.  Usually just running GF experience will autodetect the correct driver and update it with a click.  Then just update windows.  I would put money on it needing a driver update.
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
