Probably the pump starting up, so  the water moves around.
Or perhaps this is the noise of the fans? Usually they spin up to a high RPM at startup to 'push out' any dust. Or there is something caught in them?
Really, with this lack of info or soundclip I can't for sure tell you anything. If this concerns you though, you should contact NZXT support.
