I realize that these can more-or-less be looked-up on Adobe's website, but they are vague. My father is looking to do some photo manipulation/touchup with high-resolution scans of film negatives, and would like to have a dedicated desktop in his work-space for it, since his laptop isn't always there. I've been considering just donating some parts to the cause as I have a ton of stuff sitting around, but I don't want to bother if it's under-powered for the process. Currently I have:
-Dell OEM mobo with a Q9505 and I could put 8gb of compatible memory in
-Dell OEM mobo with a Phenom II X6 and 8gb of memory
-Athlon 870k in a nice board with 16gb of memory, don't want to give it up if the other setups would be sufficient
I also have an older HP slim desktop with a Phenom X3 and 4gb of memory, could probably put 8gb in there but no more. Is more than 8gb nescessary for this software with 400~mb scans?
So, what are other people using for this software and what are your thoughts? I use GIMP and I don't do any work on my photos so I have no experience with it.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
