Posted December 5, 2019 I'm building a Ryzen 7 2700x PC and I can't decide if I should have the Be quiet! dark rock pro 4 or the Phanteks PH-TC14PE Link to comment https://linustechtips.com/topic/1131427-be-quiet-dark-rock-pro-4-or-phanteks-ph-tc14pe/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 5, 2019 the cheaper one is better CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1131427-be-quiet-dark-rock-pro-4-or-phanteks-ph-tc14pe/#findComment-13104263 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 5, 2019 Author 2 minutes ago, Jurrunio said: the cheaper one is better What do you mean by that? do they perform similarly? Link to comment https://linustechtips.com/topic/1131427-be-quiet-dark-rock-pro-4-or-phanteks-ph-tc14pe/#findComment-13104271 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 5, 2019 7 minutes ago, guby26 said: What do you mean by that? do they perform similarly? Yes, to the point that price will determine the victor CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1131427-be-quiet-dark-rock-pro-4-or-phanteks-ph-tc14pe/#findComment-13104297 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 5, 2019 Author 1 minute ago, Jurrunio said: Yes, to the point that price will determine the victor Got it, thank you very much for the help it looks like I'm going with the Phanteks. Link to comment https://linustechtips.com/topic/1131427-be-quiet-dark-rock-pro-4-or-phanteks-ph-tc14pe/#findComment-13104307 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
