Distance for curved monitors?
Solved by SolarNova,
12 minutes ago, chrynok said:I recently bought a curved Samsung monitor model C24F390FHE with a 19 degree curve. They usually state how for you have to sit away from a curved screen with specs like 1800r meaning you have to sit 1800mm away from the screen. I can't find the r spec for this monitor, Does anyone have an idea how far is the optimal viewing distance for a 19 degree monitor?
https://www.samsung.com/sg/monitors/c24f390fhe/
QuoteWrapping around your field of vision, the 1800R screen — with its 1800mm radius of arc for greater curvature
