Need Help with homelab server PSU
Solved by Guest,
That chassis is made for a lower wattage PSU with an 80mm exhaust.
But if you're looking for something higher wattage due to the dual CPUs, you're probably going to want to opt for a good SFX PSU with an SFX to ATX bracket. While most higher wattage SFX PSUs have an 80~92mm fan mounted on the top/bottom as opposed to front/rear, the bracket will give you the extra space the PSU needs to allow air into the PSU.
