Im trying to figure out the best way to tame the inferno that is my Rx 570 armor GPU, i have researched about as far as i can and the only solution i have seen that might work is the NZXT g12 but i want to make sure this is the best solution. If there is a better solution that cost more i would rather do it once right rather than two times. Any help would be the much appreciated thank you.
https://linustechtips.com/topic/1130880-rx-570-armor-water-cooling/
The cost of the Kraken G12 + AIO would be more than what the MSI RX 570 Armor is worth... And you'd still be left with an RX 570 graphics card.
You're better off putting the money towards a better graphics card.
Water cooled 570 < air cooled 580
Primary PC:
