Audio card with optical connection for 5.1
By
TheSpawnAngel
in Audio
in Audio
Solved by Kalm_Traveler,
If you must use the optical cable, Soundblaster Z indeed still support Dolby Digital Live encoding (as well as the slightly superior DTS Connect encoding).
I was using one in my home theater for the last few years, works great. Down to a 2 speaker config now as I'm in early stages of preparing to move.
TECHNICAL GAMER ·
Posted in Troubleshooting1 -
GOATWD ·
Posted in Graphics Cards4 -
3
3
remo233 ·
Posted in Graphics Cards7 -
Jackie55 ·
Posted in Troubleshooting10 -
Aussie_Avo ·
Posted in Cooling9
