1 minute ago, saif961 said:
i just bought a new asus strix z390f and i9 9900k, my brother's friend said i dont need thermalpaste if its new and i  only need it if i replace my CPU is that true?
It depends what cpu cooler you are going to use since the 9900k doesnt come with a cooler. some coolers come with pre applied thermal paste some dont.
The Beast:
 i9 9900k (5.1Ghz all cores)
2080ti FE
32gb 2x16 trident z royal 3200c14
xi hero mobo
evga 1300 80+ gold
2x 1tb 970 pro
1tb 860 evo
6tb wd red
view 71 case
Custom loop (cpu & gpu)
420 & 360mm rads, ek water blocks.
asus PG279Q 27in 1440p 144hz ips gsync monitor
K70 mk2 k/b, G502 mouse, hyper x cloud revolver s headset.
(FOR SALE)
Sager NP8372
i7 7820hk, GTX 1070, 32gb ram, 17.3 in G sync display at 90hz. 500gb 960 evo. less than 1in thick.
Trident Z rgb 2x16 3200c14
https://linustechtips.com/main/topic/1066259-trident-z-rgb-2x16-3200c14-fs/
you walway need thermalpaste for your cpu. Do not know what your brother is saying. If the i9 or the mobo comes with thermal paste (they dont) the n you can use the thermalpaste that came from your products.
Not true. Your cpu always needs thermalpaste no matter what.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Just now, saif961 said:
i have a NZXT Kraken X62 280mm
Did it come with thermalpaste?
The cooler comes with thermal paste.
That cooler comes with preapplied thermal paste. No need to do extra. If it didnt have it preapplied you HAVE to put on some yourself. You can recognise most thermal pastes by the grey color. Make sure to double check your cooler before you apply it.
i didnt know they come with hold on ill open the box and check i just bought it
If it comes with thermalpaste use that. If it does not you have to buy thermalpaste. Your cpu will overheat without it 100%.
